Date/Time: Sat, 10 Oct 2026 12:55:24 +0000
Relative Volume study - documentation inconsistencies
View Count: 1036
| [2019-03-16 14:21:26] |
| User13668 - Posts: 296 |
1/ The actual study Settings & Inputs under v1882 has one called "Time Comparison Tolerance in Minutes". But there is no documentation explaining what this does or how it can be used. 2/ In the documentation for the study (Relative Volume) there is an explanation for a Setting/Input called "Display As Volume Average Volume Difference" but there is no such setting in the actual study with v1882. 3/ Ditto 2/ for "Display Cumulative Volume Average Cumulative Volume Difference" |
| [2019-03-17 19:50:33] |
We will make sure the documentation is up-to-date.
