Date/Time: Wed, 25 Nov 2026 07:55:47 +0000
Attach Trading Dom to chart window
View Count: 4016
[2019-03-16 09:10:53]
Dom7364 - Posts: 258
How do you attach a Trading DOM to a particular Chart/window?
To be clearer: All charts in a chartbook are linked in the sense that chqrt value tool cross highlights all chart except a DOM window - How do you integrate/attach the DOM window just as with the other charts in the chartbook pls?
[2019-03-17 20:01:19]
You can do this with Window >> Detach/Attach Chart on the Trading DOM.
[2025-09-12 19:50:32]
User266905 - Posts: 4
Window >> Detach/Attach Chart will show two windows under my current chartbook,
can the DOM and Chart windows integrated into one, just like how the trading window attaches to the DOM or chart window?
Date Time Of Last Edit: 2025-09-12 20:01:06
imageScreenshot 2025-09-12 125903.png / V - Attached On 2025-09-12 20:00:38 UTC - Size: 316.86 KB - 489 views
[2025-09-12 20:20:19]
We are not understanding the question. What exactly is the issue?
As to "can the DOM and Chart windows integrated into one, just like how the trading window attaches to the DOM or chart window?" the chart does this, as it has the DOM on the right side. Again, we are not certain of what you are asking here either.
[2025-09-13 00:33:28]
DOM on the right side - yes, that is enabled for Chart DOM, but not the Order Book
What I mean is to put the Order Book and Chart under one Window (you can see from the screenshot I uploaded above, the DOM Order Book on the left and Chart on the right are two separate windows, the trade window is integrated within the chart window which is what I like)
[2025-09-13 07:58:50]
DFromeaux - Posts: 29
I can't answer on behalf of the Sierra Chart team, but I can tell you that it's currently impossible to do that.
The order book window cannot be directly integrated into the chart like the DOM.
Maybe a feature request ? I don't know.
Have a good day.
imageScreenClip.png / V - Attached On 2025-09-13 07:57:36 UTC - Size: 547.28 KB - 341 views
[2025-09-15 14:19:48]
User266905:
We believe you can do everything you want within a chart and not use the Trading DOM. All of the functionality of the Trading DOM is available on a chart. Refer to the following:
Global Trade Settings Windows: Customize Chart/Trade DOM Columns (Chart Specific)
