Date/Time: Sat, 10 Oct 2026 12:55:28 +0000
TT FIX trading platform service
View Count: 1604
[2019-03-16 06:38:35]
User363775 - Posts: 25
Hi Sierrachart team,
I wish to inquire about the TT FIX trading platform service hence why I created the account only to realise that the free trial starts immediately, is there anyway we can put the trial period on hold, as I want to take advantage of the Sierra software free trial period later in the future.
I am with IB broker and based in Australia at the moment, for the live data feeds, Sierra does not offer Australian future products, so if I get third party Australian futures data but use Sierrachart Live data for CMEs, 2 data feeds, anything I need to be made aware of?
What if Sierrachart Live data feeds and 3 external data feeds?
Secondly, Interactive Brokers does not fall under the list of the clearing firms to take advantage of the above, is that correct?
Also, to take advantage of the CME discounted live data feeds, will it be void if my brokerage account is under company name?
Kind Regards,
Jackson
Date Time Of Last Edit: 2019-03-16 21:41:07
[2019-03-17 07:17:00]
When you want a new trial just make reference to this support request and we will extend the trial.
If you are going to be using Interactive Brokers, in this particular case there is not going to be another source for the Australian real-time futures data other than Interactive Brokers. That is all that could be used. The only other source would be CQG for this data and you could trade through a CQG account.
Not sure about this. You need to ask the exchange itself.
Date Time Of Last Edit: 2019-03-17 18:11:00
[2019-03-17 08:43:15]
"If you are going to be using Interactive Brokers, in this particular case there is not going to be another source for the Australian real-time futures data other than Interactive Brokers. That is all that could be used. The only other source would be CQG for this data and you could trade through a CQG account."
Would you please kindly clarify, are you saying I cannot do this for the Sierrachart Order Routing via TT only, or I cant do this in general?
my original setup plan is: Sierrachart (trading platform), wit Sierrachart live data feed for CME products, and IB live market data feed for Australian Futures, then IB as my order routing, an my original setup still be done if not for this order routing?
Date Time Of Last Edit: 2019-03-17 19:31:42
[2019-03-17 19:33:45]
To be clear what we are referring to is there is not another source for the Australian real-time futures data other than Interactive Brokers and CQG. This data is not provided by the Sierra Chart Exchange Data Feed.
If you were to use the Sierra Chart order routing based on TT where would you get the real time Australian futures data from? If you can get that from CQG or from Interactive Brokers it is possible through Symbol Settings to patch that in to the instance of Sierra Chart using the Sierra Chart order routing.
Yes this will work.
Date Time Of Last Edit: 2019-03-17 19:34:09
[2019-03-18 02:24:34]
"Sierrachart (trading platform), wit Sierrachart live data feed for CME products, and IB live market data feed for Australian Futures, then IB as my order routing, an my original setup still be done if not for this order routing?"
Yes this will work.
So the below will not work:
"Sierrachart (trading platform), wit Sierrachart live data feed for CME products, and IB live market data feed for Australian Futures, then Sierrachart Order Routing Via TT, with IB as my order execution Broker, as its not in the list of approved clearing firms is that right?
[2019-03-18 03:30:53]
Yes that is correct.
