Date/Time: Sun, 15 Nov 2026 15:47:06 +0000
Spreadsheet Study: Get all the data in the row of one column.
View Count: 1014
| [2019-03-16 03:03:43] |
| ||||||||||||||||||||| - Posts: 18 |
What is the function code to call in every available data in a specific column? I want to use it on a SUM function, I want to sum all the data in one column/cell, I can't just type SUM(A), SUM(B), SUM(C).
| [2019-03-16 17:19:40] |
| ForgivingComputers.com - Posts: 1253 |
If you have 1000 rows, then the sum of all entries in column x is: =sum(X3:X1002)
| [2019-03-17 00:10:43] |
| ||||||||||||||||||||| - Posts: 18 |
Thank you. This is exactly my current solution. |
