Date/Time: Sat, 10 Oct 2026 12:55:28 +0000
Cant connect to rithmic!!Help
View Count: 1643
[2019-03-15 19:14:16]
User431526 - Posts: 6
I try connect to rithmic. But see this error
https://gyazo.com/5834f2e0cf420d3429ad010ade108ecc
A go to this folder and cant find folder "Rim"!!!
https://gyazo.com/eaf8bfa9f22447a192c8ab9f5fc336dc
PLS HELP! How i can start Sierra with Rithmic without errors
[2019-03-15 19:15:35]
Sierra Chart - Max - Posts: 5977
Refer to step #3 in the Rithmic setup instructions here:
Rithmic Trading Platform Service: Setup Instructions
Sierra Chart Support
[2019-03-15 19:46:04]
UPDATE!!! AND NO folder "RIM"!!!
What i need do now? can you help me?
[2019-03-15 20:00:38]
And in email i see
Ending Date (YYYY-MM-DD): 2019-03-30
Software Service Package: Trial
Why trial, if i buy in AMP "Sierra Chart with Advanced Features (Service Package 5)"!!!!
[2019-03-16 22:40:00]
You need to enable the option to Install Optional Components on the installer. Update Sierra Chart again through Help >> Download Current Version and enable that option.
In regards to post #4, you need to ask AMP about this.
