Date/Time: Thu, 19 Nov 2026 21:33:05 +0000
C++ code
View Count: 2513
| [2019-03-15 19:04:38] |
| aknsyu71@gmail - Posts: 60 |
Dear sierra progammers, You guys have provided a great example in the GDIExample.cpp of how to draw a rectangle in the window. Would you be able to expand on this with a sample of how to use WM_LBUTTONDOWN to process mouse clicks on such a rectangle drawing? I got nowhere after hours of trying as I can handle ACSIL but not C++ I've written the COT indicator in the Custom Study store and hope to add some more useful study's for your users in the future. Hope you can help. Kind Regards, Andrej |
| [2019-03-17 19:35:51] |
The pointer events can only be received through a custom study according to the method documented here: Advanced Custom Study Interaction With Menus, Control Bar Buttons, Pointer Events Since they are received by a Sierra Chart window you have to rely on getting them through ACSIL. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2019-03-22 18:30:16] |
Hi, we have the sc.ActiveToolYPosition for the Y-axis coordinate in pixels. Is there any way to obtain the X-axis coordinates in pixels (I dont need the index but rather the pixel position) ? thanks |
| [2019-03-22 18:44:27] |
You can use this function to obtain that for a particular bar index: sc.BarIndexToXPixelCoordinate Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
