Date/Time: Thu, 05 Nov 2026 21:06:32 +0000
Future data is real futures data or CFD data?
View Count: 1029
| [2019-03-15 15:21:10] |
| toby709 - Posts: 1 |
I want to join the USD286 data plan with historical and real time data service. May I know the data is real time trading data from CME or HKEX or it's from CFD? I will go if the data is based on real time exchange data. Thanks for checking and advice in advance. Toby |
| [2019-03-15 17:44:43] |
Real-time data for those exchanges is supported but that is an extra cost or requires an external service. Sierra Chart also provides CFD data as well. For more information about real-time future data, refer to: Is Historical and Real-time Data Included? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
