Date/Time: Fri, 20 Nov 2026 01:49:50 +0000
Cumulative Delta - Trades
View Count: 2368
| [2019-03-15 12:43:56] |
| infpz - Posts: 826 |
Is it possible to filter out trades less than a certain size when determining cumulative delta? For example, only trades that are 20 contracts or higher are included in the calculation?
| [2019-03-15 16:49:19] |
Yes you just need to use the Volume Filtering setting: Chart Settings: Volume Filter (Chart >> Chart Settings >> Data Limiting >> Volume Filter Settings menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
