Date/Time: Sat, 10 Oct 2026 12:55:27 +0000
rithmic
View Count: 980
| [2019-03-15 09:37:52] |
| CLAUDINE PETIT-ROUX - Posts: 3 |
Hello, I can not connect, Rithmic sends an error message Can you check please thank you Claudine Date Time Of Last Edit: 2019-03-15 15:52:56
| [2019-03-15 15:52:43] |
Provide a copy of the Message Log by following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2019-03-16 03:52:59] |
I sent you u a copy for analysis thank you |
| [2019-03-17 19:40:02] |
You are getting a permission denied error: Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2019-03-16 04:46:21
Refer to: Rithmic Trading Platform Service: Permission Denied Resolution Procedure Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
