Date/Time: Sat, 10 Oct 2026 12:09:46 +0000
Bug in Volume Profile
View Count: 1148
[2019-03-14 19:17:26]
nosast2 - Posts: 73
Since updating to 1883 the command not to draw Outlines will have no effect and the outline is drawn anyways... Please see images attached.
image1880.png / V - Attached On 2019-03-14 19:17:13 UTC - Size: 3.43 KB - 326 views
image1883 settings.png / V - Attached On 2019-03-14 19:17:16 UTC - Size: 29.11 KB - 339 views
image1883.png / V - Attached On 2019-03-14 19:17:19 UTC - Size: 2.12 KB - 333 views
[2019-03-14 20:36:29]
We will look this over.
[2019-03-14 20:50:24]
John - SC Support - Posts: 48169
Can you please attach your Chartbook that is having this problem using these instructions:
[2019-03-14 21:04:39]
This is happening because you have the Width for the Outline set to 0. If you set this to 1 it will function in the same way as previous releases. We will look at putting in a check for when the setting Draw Outline When Coloring Bid Volume and Ask Volume is set to No to ignore that setting.
[2019-03-15 13:26:35]
nosast2 - Posts: 73
Ok. Doesn't make sense to me but changing the width to "1" fixed the problem.
Thx
Norman
[2019-03-15 15:05:30]
It's just the way the software works when drawing the rectangles that make up the Volume by Price bars, and it was something we overlooked when we made the change to allow the Width to be adjustable. We are looking at updating the code to prevent this.
