Date/Time: Sat, 10 Oct 2026 12:09:28 +0000
Market Depth Historical Graph
View Count: 1040
| [2019-03-14 18:47:32] |
| John Ara - Posts: 125 |
Please help me how I will be able to activate Market Depth Historical Graph study? Do I need a special data feed? Thank you. |
| [2019-03-14 21:38:06] |
| John - SC Support - Posts: 48169 |
You have everything you need to be able to use the Market Depth Historical Graph. Most likely you are not recording the Market Depth data for the symbol(s). Refer to the following set of instructions to work through where the issue may be: Market Depth Historical Graph: Market Depth Historical Graph Not Displaying For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2019-03-15 04:34:48] |
You may not actually have access to the market depth data and real-time data. What futures trading/brokerage service do you use? For the reason why we ask this question, refer to: https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#UnderstandingAccessingDataFromCME Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2019-03-15 15:36:47] |
It worked. Thank you. |
