Date/Time: Sat, 10 Oct 2026 12:08:55 +0000
ACSIL / GetChartStudySubgraphValues for user parameters ?
View Count: 1530
[2019-03-14 17:42:09]
wwwingman - Posts: 185
Hi
I would like to let the user choose a study ID from another chart.
I believe it is only possible on the current chart using sc.Input[].GetStudyID()
Can this be enhanced to be used on another chart ?
My goal is to have something similar to sc.Input[].GetChartStudySubgraphValues() but for the study parameters...
Is it possible to get the user choose a study parameter of another chart ?
Something like sc.Input[].GetChartStudySubgraphValues() but for the parameters the user chooses.
If this is too much to ask, is it possible to have an input of a study id on another chart ? which means enhancing the current sc.Input[].GetStudyID() to handle also chart number.
Please let me know if I am unclear.
Thank you.
-- W
[2019-03-15 00:39:25]
This is the function you will need to use:
ACSIL Interface Members - sc.Input Array: sc.Input[].SetStudySubgraphValues()
And refer to:
ACSIL Interface Members - Functions: sc.GetChartStudyInputFloat()
