Date/Time: Thu, 19 Nov 2026 19:40:29 +0000
RIthmic error not in troubleshooting
View Count: 968
| [2019-03-14 14:42:10] |
| sixsmith07 - Posts: 13 |
I am getting an error message that ther eis an error running DTC server program. Not sure what that means but I couldn't find it in the documentation. Thanks for the help. Image is attached. |
| Attachment Deleted. |
| [2019-03-14 16:01:37] |
Follow step 3 here: Rithmic Trading Platform Service: Setup Instructions Update the installation of Sierra Chart by following the Fast Update instructions. On the installer interface window, enable the option Install Optional Components. This is an essential step. Refer to:Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-03-14 16:02:13
