Date/Time: Sat, 10 Oct 2026 12:10:36 +0000
Issue with loading dll's
View Count: 1223
| [2019-03-14 14:17:44] |
| User255012 - Posts: 4 |
Sierra chart is loading only the default dll's but not the user developed dll's inspite of placing them in data folde DLLs: base.dll, redef.dll, UserContributedStudies.dll, UserContributedStudies_64.dll | 2019-03-14 14:12:05 |
| Attachment Deleted. |
| [2019-03-14 20:18:37] |
That message is not going to show up until you actually go to use a study from the DLL that you have created. If you have problems loading the study, then let us know and attach the Message Log per the instructions here: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2019-03-15 08:35:25] |
I couldn't even see my dll in add custom study popup. Attached below is the image. base.dll is my custom dll. Thanks. Date Time Of Last Edit: 2019-03-15 08:36:05
| [2019-03-15 08:41:08] |
Is the DLL a 64-bit DLL? Try running the 32-bit version of Sierra Chart: How to Use an Advanced Custom Study or a Study Collection: Custom Study Not Listed or Not Displaying on Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
