Date/Time: Sat, 10 Oct 2026 12:11:49 +0000
Historical data for TSX symbols
View Count: 1290
| [2019-03-13 15:21:24] |
| User104896 - Posts: 11 |
For the symbol ABX-STK-SMART-CAD, which is the required symbol format for ABX on TSX exchange via IB, the historical data is unavailable prior to March 5th 2019. How can I get the data prior to this date? I've already tried disconnecting and reconnecting, but I am using the Sierra Chart data feed for this so I don't think it is an IB issue. Thanks, |
| [2019-03-14 00:34:16] |
We have set up the symbol mapping for that symbol. Follow the instructions here to update the Symbol Settings: Global Symbol Settings: Update Global Symbol Settings After that is done, Re-download all the data in the chart by going to the chart and selecting "Edit >> Delete All Data and Download". You just need to do this once per symbol and not for each chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2019-03-14 20:16:15] |
Thank you. Will I need to request mapping for each symbol under the TSX (i.e. TD-STK-SMART-CAD, etc) one at a time? Is it possible to have all the TSX symbols with the IB formatting mapped? |
| [2019-03-14 20:47:03] |
We are setting up patterns now to map all of the symbols. This will be done in a couple of hours.
