Date/Time: Sun, 25 Oct 2026 07:43:11 +0000
Return / Risk Tool no longer working
View Count: 945
| [2019-03-12 18:36:48] |
| User606491 - Posts: 164 |
Has anyone else reported an issue with the return / risk tool? The tool has not been working because it associates the stop and entry as the same price (denominator = 0). I used to be able to click three times (stop -> entry -> target), however, I am unable to do so. It is possible that I changed the settings for the tool, but I don't see a way to restore default settings. thank you |
| [2019-03-12 20:37:10] |
No and we do not observe any problem with this drawing tool. It does support setting three different points.
