Date/Time: Sun, 25 Oct 2026 07:44:37 +0000
Horizontal lines Study on other than main chart only drawing one line
View Count: 974
| [2019-03-11 21:05:02] |
| User871277 - Posts: 34 |
Horizontal lines Study on other than main chart only drawing one line. I want to add levels to oscillators, sadly the horizontal lines study only draws one single line and that's it, no matter how hard I try. Screenshots attached. |
| [2019-03-12 22:03:13] |
| John - SC Support - Posts: 48317 |
You have to go to the Subgraph Tab and set the Draw Style for each line you want to draw to Line. By default, they are set to Ignore except for the first one. Refer to the fifth paragraph of the Horizontal Lines study documentation: Horizontal Lines For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
