Date/Time: Thu, 05 Nov 2026 19:26:25 +0000
Can't connect to Rithmic paper trading for Oneuptrader; file missing
View Count: 1235
[2019-03-08 19:06:16]
User485125 - Posts: 1
Reading Internal Order ID file. | 2019-03-08 13:54:36
Reading Trade Orders file. | 2019-03-08 13:54:36
Reading Trade Positions file. | 2019-03-08 13:54:36
Account Balance file. | 2019-03-08 13:54:36
UDPListener (1384). Port 22904 | Listening on UDP port 22904. | 2019-03-08 13:54:36
Software version: 1882 64-bit | 2019-03-08 13:54:36
Usage end date: 2019-03-23 | 2019-03-08 13:54:36
Enabled for: Advanced Features. | 2019-03-08 13:54:36
Enabled for: Advanced Features 2. | 2019-03-08 13:54:36
Enabled for: Sierra Chart Historical Data Service. | 2019-03-08 13:54:36
Allow Support for Sierra Chart Data Feeds is enabled. | 2019-03-08 13:54:36
Current selected Data/Trading service: Rithmic Trading | 2019-03-08 13:54:36
Chart Update Interval: 500 | 2019-03-08 13:54:36
Intraday Data Storage Time Unit: 1 | 2019-03-08 13:54:36
Time Zone: -05:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2019-03-08 13:54:36
2019-03-08 13:54:36 Local computer time | 2019-03-08 13:54:36
2019-03-08 18:54:36 Local computer time in UTC | 2019-03-08 13:54:36
2019-03-08 13:54:36 Local computer time in SC Time Zone | 2019-03-08 13:54:36
2019-03-08 18:54:36 Server time in UTC | 2019-03-08 13:54:36
Local computer UTC time and Server UTC time difference: 1 seconds. | 2019-03-08 13:54:36
Program path: C:\SierraChart\ | 2019-03-08 13:54:36
Data Files path: C:\SierraChart\Data\ | 2019-03-08 13:54:36
OS Version Number: 10.0 | 2019-03-08 13:54:36
Locale Setting: C | 2019-03-08 13:54:36
Checking for new symbol settings. Requested symbol settings MD5 for service code rithmic.trading. Request ID: 1. | 2019-03-08 13:54:36
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (4) | Creating socket. Using TLS 1.2. | 2019-03-08 13:54:36
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (4) | Connecting to IP: 46.4.97.203. | 2019-03-08 13:54:36
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. | 2019-03-08 13:54:36
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. | 2019-03-08 13:54:36
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed. | 2019-03-08 13:54:36
Symbol settings MD5 received. Request ID: 1. | 2019-03-08 13:54:37
Symbol settings are up-to-date for rithmic.trading. | 2019-03-08 13:54:37
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (4) | Shutdown started. Waiting for graceful close. | 2019-03-08 13:54:37
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (4) | Socket gracefully closed by remote side. | 2019-03-08 13:54:37
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (4) | Closed. | 2019-03-08 13:54:37
Received 5 login tokens. | 2019-03-08 13:54:38
HTTPS connection ID:2 to www.sierrachart.com:443 for request ID:2 (2) | Shutdown started. Waiting for graceful close. | 2019-03-08 13:54:38
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Creating socket. Using TLS 1.2. | 2019-03-08 13:54:38
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Connecting to IP: 46.4.97.203. | 2019-03-08 13:54:38
HTTPS connection ID:2 to www.sierrachart.com:443 for request ID:2 (2) | Socket gracefully closed by remote side. | 2019-03-08 13:54:38
HTTPS connection ID:2 to www.sierrachart.com:443 for request ID:2 (2) | Closed. | 2019-03-08 13:54:38
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. | 2019-03-08 13:54:39
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. | 2019-03-08 13:54:39
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Closed. | 2019-03-08 13:54:39
Rithmic Trading | Port for executable: 49900 | 2019-03-08 13:54:42
Listening socket (1400). Port 49900 | Closed. | 2019-03-08 13:54:42
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-03-08 13:54:42
Error creating process C:\SierraChart\Rim\DTCBridge.exe. Windows error code 2: The system cannot find the file specified. | 2019-03-08 13:54:42 *
Rithmic Trading | Error running DTC server program C:\SierraChart\Rim\DTCBridge.exe. | 2019-03-08 13:54:42 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-03-08 13:54:42
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-08 13:54:42
Rithmic Trading | Disconnected. | 2019-03-08 13:54:42
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-08 13:54:42
Rithmic Trading | Port for executable: 49901 | 2019-03-08 13:54:44
Listening socket (1400). Port 49901 | Closed. | 2019-03-08 13:54:44
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-03-08 13:54:44
Error creating process C:\SierraChart\Rim\DTCBridge.exe. Windows error code 2: The system cannot find the file specified. | 2019-03-08 13:54:44 *
Rithmic Trading | Error running DTC server program C:\SierraChart\Rim\DTCBridge.exe. | 2019-03-08 13:54:44 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-03-08 13:54:44
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-08 13:54:44
Rithmic Trading | Disconnected. | 2019-03-08 13:54:44
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-08 13:54:44
Rithmic Trading | Port for executable: 49902 | 2019-03-08 13:54:46
Listening socket (1400). Port 49902 | Closed. | 2019-03-08 13:54:46
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-03-08 13:54:46
Error creating process C:\SierraChart\Rim\DTCBridge.exe. Windows error code 2: The system cannot find the file specified. | 2019-03-08 13:54:46 *
Rithmic Trading | Error running DTC server program C:\SierraChart\Rim\DTCBridge.exe. | 2019-03-08 13:54:46 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-03-08 13:54:46
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-08 13:54:46
Rithmic Trading | Disconnected. | 2019-03-08 13:54:46
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-08 13:54:46
Rithmic Trading | Port for executable: 49903 | 2019-03-08 13:54:48
Listening socket (1400). Port 49903 | Closed. | 2019-03-08 13:54:48
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-03-08 13:54:48
Error creating process C:\SierraChart\Rim\DTCBridge.exe. Windows error code 2: The system cannot find the file specified. | 2019-03-08 13:54:48 *
Rithmic Trading | Error running DTC server program C:\SierraChart\Rim\DTCBridge.exe. | 2019-03-08 13:54:48 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-03-08 13:54:48
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-08 13:54:48
Rithmic Trading | Disconnected. | 2019-03-08 13:54:48
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-08 13:54:48
Rithmic Trading | Port for executable: 49904 | 2019-03-08 13:54:50
Listening socket (1400). Port 49904 | Closed. | 2019-03-08 13:54:50
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-03-08 13:54:50
Error creating process C:\SierraChart\Rim\DTCBridge.exe. Windows error code 2: The system cannot find the file specified. | 2019-03-08 13:54:50 *
Rithmic Trading | Error running DTC server program C:\SierraChart\Rim\DTCBridge.exe. | 2019-03-08 13:54:50 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-03-08 13:54:50
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-08 13:54:50
Rithmic Trading | Disconnected. | 2019-03-08 13:54:50
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-08 13:54:50
Rithmic Trading | Port for executable: 49905 | 2019-03-08 13:54:52
Listening socket (1400). Port 49905 | Closed. | 2019-03-08 13:54:52
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-03-08 13:54:52
Error creating process C:\SierraChart\Rim\DTCBridge.exe. Windows error code 2: The system cannot find the file specified. | 2019-03-08 13:54:52 *
Rithmic Trading | Error running DTC server program C:\SierraChart\Rim\DTCBridge.exe. | 2019-03-08 13:54:52 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-03-08 13:54:52
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-08 13:54:52
Rithmic Trading | Disconnected. | 2019-03-08 13:54:52
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-08 13:54:52
Rithmic Trading | Port for executable: 49906 | 2019-03-08 13:54:54
Listening socket (1400). Port 49906 | Closed. | 2019-03-08 13:54:54
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-03-08 13:54:54
Error creating process C:\SierraChart\Rim\DTCBridge.exe. Windows error code 2: The system cannot find the file specified. | 2019-03-08 13:54:54 *
Rithmic Trading | Error running DTC server program C:\SierraChart\Rim\DTCBridge.exe. | 2019-03-08 13:54:54 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-03-08 13:54:54
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-08 13:54:54
Rithmic Trading | Disconnected. | 2019-03-08 13:54:54
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-08 13:54:54
Rithmic Trading | Port for executable: 49907 | 2019-03-08 13:54:56
Listening socket (1400). Port 49907 | Closed. | 2019-03-08 13:54:56
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-03-08 13:54:56
Error creating process C:\SierraChart\Rim\DTCBridge.exe. Windows error code 2: The system cannot find the file specified. | 2019-03-08 13:54:56 *
Rithmic Trading | Error running DTC server program C:\SierraChart\Rim\DTCBridge.exe. | 2019-03-08 13:54:56 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-03-08 13:54:56
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-08 13:54:56
Rithmic Trading | Disconnected. | 2019-03-08 13:54:56
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-08 13:54:56
Rithmic Trading | Port for executable: 49909 | 2019-03-08 13:54:58
Listening socket (1400). Port 49909 | Closed. | 2019-03-08 13:54:58
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-03-08 13:54:58
Error creating process C:\SierraChart\Rim\DTCBridge.exe. Windows error code 2: The system cannot find the file specified. | 2019-03-08 13:54:58 *
Rithmic Trading | Error running DTC server program C:\SierraChart\Rim\DTCBridge.exe. | 2019-03-08 13:54:58 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-03-08 13:54:58
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-08 13:54:58
Rithmic Trading | Disconnected. | 2019-03-08 13:54:58
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-08 13:54:58
Rithmic Trading | Port for executable: 49910 | 2019-03-08 13:55:00
Listening socket (1400). Port 49910 | Closed. | 2019-03-08 13:55:00
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-03-08 13:55:00
Error creating process C:\SierraChart\Rim\DTCBridge.exe. Windows error code 2: The system cannot find the file specified. | 2019-03-08 13:55:00 *
Rithmic Trading | Error running DTC server program C:\SierraChart\Rim\DTCBridge.exe. | 2019-03-08 13:55:00 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-03-08 13:55:00
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-08 13:55:00
Rithmic Trading | Disconnected. | 2019-03-08 13:55:00
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-08 13:55:00
Rithmic Trading | Port for executable: 49911 | 2019-03-08 13:55:02
Listening socket (1400). Port 49911 | Closed. | 2019-03-08 13:55:02
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-03-08 13:55:02
Error creating process C:\SierraChart\Rim\DTCBridge.exe. Windows error code 2: The system cannot find the file specified. | 2019-03-08 13:55:02 *
Rithmic Trading | Error running DTC server program C:\SierraChart\Rim\DTCBridge.exe. | 2019-03-08 13:55:02 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-03-08 13:55:02
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-08 13:55:02
Rithmic Trading | Disconnected. | 2019-03-08 13:55:02
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-08 13:55:02
Rithmic Trading | Port for executable: 49912 | 2019-03-08 13:55:04
Listening socket (1400). Port 49912 | Closed. | 2019-03-08 13:55:04
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-03-08 13:55:04
Error creating process C:\SierraChart\Rim\DTCBridge.exe. Windows error code 2: The system cannot find the file specified. | 2019-03-08 13:55:04 *
Rithmic Trading | Error running DTC server program C:\SierraChart\Rim\DTCBridge.exe. | 2019-03-08 13:55:04 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-03-08 13:55:04
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-08 13:55:04
Rithmic Trading | Disconnected. | 2019-03-08 13:55:04
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-08 13:55:04
Rithmic Trading | Port for executable: 49913 | 2019-03-08 13:55:06
Listening socket (1400). Port 49913 | Closed. | 2019-03-08 13:55:06
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-03-08 13:55:06
Error creating process C:\SierraChart\Rim\DTCBridge.exe. Windows error code 2: The system cannot find the file specified. | 2019-03-08 13:55:06 *
Rithmic Trading | Error running DTC server program C:\SierraChart\Rim\DTCBridge.exe. | 2019-03-08 13:55:06 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-03-08 13:55:06
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-08 13:55:06
Rithmic Trading | Disconnected. | 2019-03-08 13:55:06
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-08 13:55:06
Rithmic Trading | Port for executable: 49914 | 2019-03-08 13:55:08
Listening socket (1400). Port 49914 | Closed. | 2019-03-08 13:55:08
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-03-08 13:55:08
Error creating process C:\SierraChart\Rim\DTCBridge.exe. Windows error code 2: The system cannot find the file specified. | 2019-03-08 13:55:08 *
Rithmic Trading | Error running DTC server program C:\SierraChart\Rim\DTCBridge.exe. | 2019-03-08 13:55:08 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-03-08 13:55:08
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-08 13:55:08
Rithmic Trading | Disconnected. | 2019-03-08 13:55:08
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-08 13:55:08
Rithmic Trading | Port for executable: 49915 | 2019-03-08 13:55:10
Listening socket (1408). Port 49915 | Closed. | 2019-03-08 13:55:10
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-03-08 13:55:10
Error creating process C:\SierraChart\Rim\DTCBridge.exe. Windows error code 2: The system cannot find the file specified. | 2019-03-08 13:55:10 *
Rithmic Trading | Error running DTC server program C:\SierraChart\Rim\DTCBridge.exe. | 2019-03-08 13:55:10 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-03-08 13:55:10
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-08 13:55:10
Rithmic Trading | Disconnected. | 2019-03-08 13:55:10
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-08 13:55:10
Rithmic Trading | Port for executable: 49916 | 2019-03-08 13:55:12
Listening socket (700). Port 49916 | Closed. | 2019-03-08 13:55:12
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-03-08 13:55:12
Error creating process C:\SierraChart\Rim\DTCBridge.exe. Windows error code 2: The system cannot find the file specified. | 2019-03-08 13:55:12 *
Rithmic Trading | Error running DTC server program C:\SierraChart\Rim\DTCBridge.exe. | 2019-03-08 13:55:12 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-03-08 13:55:12
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-08 13:55:12
Rithmic Trading | Disconnected. | 2019-03-08 13:55:12
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-08 13:55:12
Rithmic Trading | Port for executable: 49926 | 2019-03-08 13:55:14
Listening socket (700). Port 49926 | Closed. | 2019-03-08 13:55:14
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-03-08 13:55:14
Error creating process C:\SierraChart\Rim\DTCBridge.exe. Windows error code 2: The system cannot find the file specified. | 2019-03-08 13:55:14 *
Rithmic Trading | Error running DTC server program C:\SierraChart\Rim\DTCBridge.exe. | 2019-03-08 13:55:14 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-03-08 13:55:14
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-08 13:55:14
Rithmic Trading | Disconnected. | 2019-03-08 13:55:14
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-08 13:55:14
Rithmic Trading | Port for executable: 49927 | 2019-03-08 13:55:16
Listening socket (700). Port 49927 | Closed. | 2019-03-08 13:55:16
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-03-08 13:55:16
Error creating process C:\SierraChart\Rim\DTCBridge.exe. Windows error code 2: The system cannot find the file specified. | 2019-03-08 13:55:16 *
Rithmic Trading | Error running DTC server program C:\SierraChart\Rim\DTCBridge.exe. | 2019-03-08 13:55:16 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-03-08 13:55:16
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-08 13:55:16
Rithmic Trading | Disconnected. | 2019-03-08 13:55:16
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-08 13:55:16
Rithmic Trading | Port for executable: 49929 | 2019-03-08 13:55:18
Listening socket (1408). Port 49929 | Closed. | 2019-03-08 13:55:18
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-03-08 13:55:18
Error creating process C:\SierraChart\Rim\DTCBridge.exe. Windows error code 2: The system cannot find the file specified. | 2019-03-08 13:55:18 *
Rithmic Trading | Error running DTC server program C:\SierraChart\Rim\DTCBridge.exe. | 2019-03-08 13:55:18 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-03-08 13:55:18
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-08 13:55:18
Rithmic Trading | Disconnected. | 2019-03-08 13:55:18
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-08 13:55:18
Rithmic Trading | Port for executable: 49930 | 2019-03-08 13:55:20
Listening socket (1408). Port 49930 | Closed. | 2019-03-08 13:55:21
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-03-08 13:55:21
Error creating process C:\SierraChart\Rim\DTCBridge.exe. Windows error code 2: The system cannot find the file specified. | 2019-03-08 13:55:21 *
Rithmic Trading | Error running DTC server program C:\SierraChart\Rim\DTCBridge.exe. | 2019-03-08 13:55:21 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-03-08 13:55:21
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-08 13:55:21
Rithmic Trading | Disconnected. | 2019-03-08 13:55:21
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-08 13:55:21
Rithmic Trading | Port for executable: 49933 | 2019-03-08 13:55:23
Listening socket (1408). Port 49933 | Closed. | 2019-03-08 13:55:23
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-03-08 13:55:23
Error creating process C:\SierraChart\Rim\DTCBridge.exe. Windows error code 2: The system cannot find the file specified. | 2019-03-08 13:55:23 *
Rithmic Trading | Error running DTC server program C:\SierraChart\Rim\DTCBridge.exe. | 2019-03-08 13:55:23 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-03-08 13:55:23
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-08 13:55:23
Rithmic Trading | Disconnected. | 2019-03-08 13:55:23
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-08 13:55:23
Rithmic Trading | Port for executable: 49934 | 2019-03-08 13:55:25
Listening socket (1408). Port 49934 | Closed. | 2019-03-08 13:55:25
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-03-08 13:55:25
Error creating process C:\SierraChart\Rim\DTCBridge.exe. Windows error code 2: The system cannot find the file specified. | 2019-03-08 13:55:25 *
Rithmic Trading | Error running DTC server program C:\SierraChart\Rim\DTCBridge.exe. | 2019-03-08 13:55:25 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-03-08 13:55:25
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-08 13:55:25
Rithmic Trading | Disconnected. | 2019-03-08 13:55:25
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-08 13:55:25
Rithmic Trading | Port for executable: 49935 | 2019-03-08 13:55:27
Listening socket (1408). Port 49935 | Closed. | 2019-03-08 13:55:27
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-03-08 13:55:27
Error creating process C:\SierraChart\Rim\DTCBridge.exe. Windows error code 2: The system cannot find the file specified. | 2019-03-08 13:55:27 *
Rithmic Trading | Error running DTC server program C:\SierraChart\Rim\DTCBridge.exe. | 2019-03-08 13:55:27 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-03-08 13:55:27
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-08 13:55:27
Rithmic Trading | Disconnected. | 2019-03-08 13:55:27
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-08 13:55:27
Rithmic Trading | Port for executable: 49936 | 2019-03-08 13:55:29
Listening socket (1408). Port 49936 | Closed. | 2019-03-08 13:55:29
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-03-08 13:55:29
Error creating process C:\SierraChart\Rim\DTCBridge.exe. Windows error code 2: The system cannot find the file specified. | 2019-03-08 13:55:29 *
Rithmic Trading | Error running DTC server program C:\SierraChart\Rim\DTCBridge.exe. | 2019-03-08 13:55:29 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-03-08 13:55:29
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-08 13:55:29
Rithmic Trading | Disconnected. | 2019-03-08 13:55:29
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-08 13:55:29
Rithmic Trading | Port for executable: 49937 | 2019-03-08 13:55:31
Listening socket (1400). Port 49937 | Closed. | 2019-03-08 13:55:31
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-03-08 13:55:31
Error creating process C:\SierraChart\Rim\DTCBridge.exe. Windows error code 2: The system cannot find the file specified. | 2019-03-08 13:55:31 *
Rithmic Trading | Error running DTC server program C:\SierraChart\Rim\DTCBridge.exe. | 2019-03-08 13:55:31 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-03-08 13:55:31
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-08 13:55:31
Rithmic Trading | Disconnected. | 2019-03-08 13:55:31
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-08 13:55:31
Rithmic Trading | Port for executable: 49938 | 2019-03-08 13:55:33
Listening socket (1400). Port 49938 | Closed. | 2019-03-08 13:55:33
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-03-08 13:55:33
Error creating process C:\SierraChart\Rim\DTCBridge.exe. Windows error code 2: The system cannot find the file specified. | 2019-03-08 13:55:33 *
Rithmic Trading | Error running DTC server program C:\SierraChart\Rim\DTCBridge.exe. | 2019-03-08 13:55:33 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-03-08 13:55:33
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-08 13:55:33
Rithmic Trading | Disconnected. | 2019-03-08 13:55:33
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-08 13:55:33
Rithmic Trading | Port for executable: 49939 | 2019-03-08 13:55:35
Listening socket (1400). Port 49939 | Closed. | 2019-03-08 13:55:35
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-03-08 13:55:35
Error creating process C:\SierraChart\Rim\DTCBridge.exe. Windows error code 2: The system cannot find the file specified. | 2019-03-08 13:55:35 *
Rithmic Trading | Error running DTC server program C:\SierraChart\Rim\DTCBridge.exe. | 2019-03-08 13:55:35 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-03-08 13:55:35
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-08 13:55:35
Rithmic Trading | Disconnected. | 2019-03-08 13:55:35
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-08 13:55:35
Rithmic Trading | Port for executable: 49941 | 2019-03-08 13:55:37
Listening socket (1400). Port 49941 | Closed. | 2019-03-08 13:55:37
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-03-08 13:55:37
Error creating process C:\SierraChart\Rim\DTCBridge.exe. Windows error code 2: The system cannot find the file specified. | 2019-03-08 13:55:37 *
Rithmic Trading | Error running DTC server program C:\SierraChart\Rim\DTCBridge.exe. | 2019-03-08 13:55:37 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-03-08 13:55:37
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-08 13:55:37
Rithmic Trading | Disconnected. | 2019-03-08 13:55:37
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-08 13:55:37
Rithmic Trading | Port for executable: 49942 | 2019-03-08 13:55:39
Listening socket (1400). Port 49942 | Closed. | 2019-03-08 13:55:39
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-03-08 13:55:39
Error creating process C:\SierraChart\Rim\DTCBridge.exe. Windows error code 2: The system cannot find the file specified. | 2019-03-08 13:55:39 *
Rithmic Trading | Error running DTC server program C:\SierraChart\Rim\DTCBridge.exe. | 2019-03-08 13:55:39 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-03-08 13:55:39
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-08 13:55:39
Rithmic Trading | Disconnected. | 2019-03-08 13:55:39
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-08 13:55:39
Rithmic Trading | Port for executable: 49943 | 2019-03-08 13:55:41
Listening socket (1400). Port 49943 | Closed. | 2019-03-08 13:55:41
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-03-08 13:55:41
Error creating process C:\SierraChart\Rim\DTCBridge.exe. Windows error code 2: The system cannot find the file specified. | 2019-03-08 13:55:41 *
Rithmic Trading | Error running DTC server program C:\SierraChart\Rim\DTCBridge.exe. | 2019-03-08 13:55:41 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-03-08 13:55:41
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-08 13:55:41
Rithmic Trading | Disconnected. | 2019-03-08 13:55:41
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-08 13:55:41
Rithmic Trading | Port for executable: 49944 | 2019-03-08 13:55:43
Listening socket (1400). Port 49944 | Closed. | 2019-03-08 13:55:43
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-03-08 13:55:43
Error creating process C:\SierraChart\Rim\DTCBridge.exe. Windows error code 2: The system cannot find the file specified. | 2019-03-08 13:55:43 *
Rithmic Trading | Error running DTC server program C:\SierraChart\Rim\DTCBridge.exe. | 2019-03-08 13:55:43 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-03-08 13:55:43
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-08 13:55:43
Rithmic Trading | Disconnected. | 2019-03-08 13:55:43
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-08 13:55:43
Rithmic Trading | Port for executable: 49945 | 2019-03-08 13:55:45
Listening socket (1400). Port 49945 | Closed. | 2019-03-08 13:55:45
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-03-08 13:55:45
Error creating process C:\SierraChart\Rim\DTCBridge.exe. Windows error code 2: The system cannot find the file specified. | 2019-03-08 13:55:45 *
Rithmic Trading | Error running DTC server program C:\SierraChart\Rim\DTCBridge.exe. | 2019-03-08 13:55:45 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-03-08 13:55:45
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-08 13:55:45
Rithmic Trading | Disconnected. | 2019-03-08 13:55:45
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-08 13:55:45
Rithmic Trading | Port for executable: 49947 | 2019-03-08 13:55:47
Listening socket (1400). Port 49947 | Closed. | 2019-03-08 13:55:47
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-03-08 13:55:47
Error creating process C:\SierraChart\Rim\DTCBridge.exe. Windows error code 2: The system cannot find the file specified. | 2019-03-08 13:55:47 *
Rithmic Trading | Error running DTC server program C:\SierraChart\Rim\DTCBridge.exe. | 2019-03-08 13:55:47 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-03-08 13:55:47
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-08 13:55:47
Rithmic Trading | Disconnected. | 2019-03-08 13:55:47
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-08 13:55:47
Rithmic Trading | Port for executable: 49948 | 2019-03-08 13:55:49
Listening socket (1400). Port 49948 | Closed. | 2019-03-08 13:55:49
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-03-08 13:55:49
Error creating process C:\SierraChart\Rim\DTCBridge.exe. Windows error code 2: The system cannot find the file specified. | 2019-03-08 13:55:49 *
Rithmic Trading | Error running DTC server program C:\SierraChart\Rim\DTCBridge.exe. | 2019-03-08 13:55:49 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-03-08 13:55:49
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-08 13:55:49
Rithmic Trading | Disconnected. | 2019-03-08 13:55:49
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-08 13:55:49
Rithmic Trading | Port for executable: 49949 | 2019-03-08 13:55:51
Listening socket (1400). Port 49949 | Closed. | 2019-03-08 13:55:51
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-03-08 13:55:51
Error creating process C:\SierraChart\Rim\DTCBridge.exe. Windows error code 2: The system cannot find the file specified. | 2019-03-08 13:55:51 *
Rithmic Trading | Error running DTC server program C:\SierraChart\Rim\DTCBridge.exe. | 2019-03-08 13:55:51 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-03-08 13:55:51
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-08 13:55:51
Rithmic Trading | Disconnected. | 2019-03-08 13:55:51
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-08 13:55:51
Rithmic Trading | Port for executable: 49950 | 2019-03-08 13:55:53
Listening socket (1048). Port 49950 | Closed. | 2019-03-08 13:55:53
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-03-08 13:55:53
Error creating process C:\SierraChart\Rim\DTCBridge.exe. Windows error code 2: The system cannot find the file specified. | 2019-03-08 13:55:53 *
Rithmic Trading | Error running DTC server program C:\SierraChart\Rim\DTCBridge.exe. | 2019-03-08 13:55:53 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-03-08 13:55:53
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-08 13:55:53
Rithmic Trading | Disconnected. | 2019-03-08 13:55:53
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-08 13:55:53
Rithmic Trading | Port for executable: 49951 | 2019-03-08 13:55:55
Listening socket (1048). Port 49951 | Closed. | 2019-03-08 13:55:55
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-03-08 13:55:55
Error creating process C:\SierraChart\Rim\DTCBridge.exe. Windows error code 2: The system cannot find the file specified. | 2019-03-08 13:55:55 *
Rithmic Trading | Error running DTC server program C:\SierraChart\Rim\DTCBridge.exe. | 2019-03-08 13:55:55 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-03-08 13:55:55
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-08 13:55:55
Rithmic Trading | Disconnected. | 2019-03-08 13:55:55
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-08 13:55:55
Rithmic Trading | Port for executable: 49952 | 2019-03-08 13:55:57
Listening socket (1048). Port 49952 | Closed. | 2019-03-08 13:55:57
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-03-08 13:55:57
Error creating process C:\SierraChart\Rim\DTCBridge.exe. Windows error code 2: The system cannot find the file specified. | 2019-03-08 13:55:57 *
Rithmic Trading | Error running DTC server program C:\SierraChart\Rim\DTCBridge.exe. | 2019-03-08 13:55:57 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-03-08 13:55:57
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-08 13:55:57
Rithmic Trading | Disconnected. | 2019-03-08 13:55:57
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-08 13:55:57
Rithmic Trading | Port for executable: 49953 | 2019-03-08 13:55:59
Listening socket (1048). Port 49953 | Closed. | 2019-03-08 13:55:59
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-03-08 13:55:59
Error creating process C:\SierraChart\Rim\DTCBridge.exe. Windows error code 2: The system cannot find the file specified. | 2019-03-08 13:55:59 *
Rithmic Trading | Error running DTC server program C:\SierraChart\Rim\DTCBridge.exe. | 2019-03-08 13:55:59 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-03-08 13:55:59
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-08 13:55:59
Rithmic Trading | Disconnected. | 2019-03-08 13:55:59
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-08 13:55:59
Rithmic Trading | Port for executable: 49954 | 2019-03-08 13:56:01
Listening socket (1048). Port 49954 | Closed. | 2019-03-08 13:56:01
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-03-08 13:56:01
Error creating process C:\SierraChart\Rim\DTCBridge.exe. Windows error code 2: The system cannot find the file specified. | 2019-03-08 13:56:01 *
Rithmic Trading | Error running DTC server program C:\SierraChart\Rim\DTCBridge.exe. | 2019-03-08 13:56:01 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-03-08 13:56:01
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-08 13:56:01
Rithmic Trading | Disconnected. | 2019-03-08 13:56:01
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-08 13:56:01
Rithmic Trading | Port for executable: 49955 | 2019-03-08 13:56:03
Listening socket (1048). Port 49955 | Closed. | 2019-03-08 13:56:03
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-03-08 13:56:03
Error creating process C:\SierraChart\Rim\DTCBridge.exe. Windows error code 2: The system cannot find the file specified. | 2019-03-08 13:56:03 *
Rithmic Trading | Error running DTC server program C:\SierraChart\Rim\DTCBridge.exe. | 2019-03-08 13:56:03 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-03-08 13:56:03
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-08 13:56:03
Rithmic Trading | Disconnected. | 2019-03-08 13:56:03
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-08 13:56:03
Rithmic Trading | Port for executable: 49956 | 2019-03-08 13:56:05
Listening socket (1048). Port 49956 | Closed. | 2019-03-08 13:56:05
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-03-08 13:56:05
Error creating process C:\SierraChart\Rim\DTCBridge.exe. Windows error code 2: The system cannot find the file specified. | 2019-03-08 13:56:05 *
Rithmic Trading | Error running DTC server program C:\SierraChart\Rim\DTCBridge.exe. | 2019-03-08 13:56:05 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-03-08 13:56:05
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-08 13:56:05
Rithmic Trading | Disconnected. | 2019-03-08 13:56:05
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-08 13:56:05
Rithmic Trading | Port for executable: 49957 | 2019-03-08 13:56:07
Listening socket (1400). Port 49957 | Closed. | 2019-03-08 13:56:07
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-03-08 13:56:07
Error creating process C:\SierraChart\Rim\DTCBridge.exe. Windows error code 2: The system cannot find the file specified. | 2019-03-08 13:56:07 *
Rithmic Trading | Error running DTC server program C:\SierraChart\Rim\DTCBridge.exe. | 2019-03-08 13:56:07 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-03-08 13:56:07
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-08 13:56:07
Rithmic Trading | Disconnected. | 2019-03-08 13:56:07
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-08 13:56:07
Rithmic Trading | Port for executable: 49958 | 2019-03-08 13:56:09
Listening socket (1400). Port 49958 | Closed. | 2019-03-08 13:56:09
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-03-08 13:56:09
Error creating process C:\SierraChart\Rim\DTCBridge.exe. Windows error code 2: The system cannot find the file specified. | 2019-03-08 13:56:09 *
Rithmic Trading | Error running DTC server program C:\SierraChart\Rim\DTCBridge.exe. | 2019-03-08 13:56:09 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-03-08 13:56:09
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-08 13:56:09
Rithmic Trading | Disconnected. | 2019-03-08 13:56:09
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-08 13:56:09
Rithmic Trading | Port for executable: 49961 | 2019-03-08 13:56:11
Listening socket (1400). Port 49961 | Closed. | 2019-03-08 13:56:11
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-03-08 13:56:11
Error creating process C:\SierraChart\Rim\DTCBridge.exe. Windows error code 2: The system cannot find the file specified. | 2019-03-08 13:56:11 *
Rithmic Trading | Error running DTC server program C:\SierraChart\Rim\DTCBridge.exe. | 2019-03-08 13:56:11 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-03-08 13:56:11
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-08 13:56:11
Rithmic Trading | Disconnected. | 2019-03-08 13:56:11
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-08 13:56:11
Rithmic Trading | Port for executable: 49962 | 2019-03-08 13:56:13
Listening socket (1400). Port 49962 | Closed. | 2019-03-08 13:56:13
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-03-08 13:56:13
Error creating process C:\SierraChart\Rim\DTCBridge.exe. Windows error code 2: The system cannot find the file specified. | 2019-03-08 13:56:13 *
Rithmic Trading | Error running DTC server program C:\SierraChart\Rim\DTCBridge.exe. | 2019-03-08 13:56:13 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-03-08 13:56:13
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-08 13:56:13
Rithmic Trading | Disconnected. | 2019-03-08 13:56:14
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-08 13:56:14
Rithmic Trading | Port for executable: 49963 | 2019-03-08 13:56:16
Listening socket (1048). Port 49963 | Closed. | 2019-03-08 13:56:16
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-03-08 13:56:16
Error creating process C:\SierraChart\Rim\DTCBridge.exe. Windows error code 2: The system cannot find the file specified. | 2019-03-08 13:56:16 *
Rithmic Trading | Error running DTC server program C:\SierraChart\Rim\DTCBridge.exe. | 2019-03-08 13:56:16 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-03-08 13:56:16
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-08 13:56:16
Rithmic Trading | Disconnected. | 2019-03-08 13:56:16
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-08 13:56:16
Rithmic Trading | Port for executable: 49964 | 2019-03-08 13:56:18
Listening socket (1048). Port 49964 | Closed. | 2019-03-08 13:56:18
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-03-08 13:56:18
Error creating process C:\SierraChart\Rim\DTCBridge.exe. Windows error code 2: The system cannot find the file specified. | 2019-03-08 13:56:18 *
Rithmic Trading | Error running DTC server program C:\SierraChart\Rim\DTCBridge.exe. | 2019-03-08 13:56:18 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-03-08 13:56:18
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-08 13:56:18
Rithmic Trading | Disconnected. | 2019-03-08 13:56:18
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-08 13:56:18
Rithmic Trading | Port for executable: 49965 | 2019-03-08 13:56:20
Listening socket (1048). Port 49965 | Closed. | 2019-03-08 13:56:20
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-03-08 13:56:20
Error creating process C:\SierraChart\Rim\DTCBridge.exe. Windows error code 2: The system cannot find the file specified. | 2019-03-08 13:56:20 *
Rithmic Trading | Error running DTC server program C:\SierraChart\Rim\DTCBridge.exe. | 2019-03-08 13:56:20 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-03-08 13:56:20
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-08 13:56:20
Rithmic Trading | Disconnected. | 2019-03-08 13:56:20
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-08 13:56:20
Rithmic Trading | Port for executable: 49966 | 2019-03-08 13:56:22
Listening socket (1048). Port 49966 | Closed. | 2019-03-08 13:56:22
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-03-08 13:56:22
Error creating process C:\SierraChart\Rim\DTCBridge.exe. Windows error code 2: The system cannot find the file specified. | 2019-03-08 13:56:22 *
Rithmic Trading | Error running DTC server program C:\SierraChart\Rim\DTCBridge.exe. | 2019-03-08 13:56:22 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-03-08 13:56:22
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-08 13:56:22
Rithmic Trading | Disconnected. | 2019-03-08 13:56:22
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-08 13:56:22
Rithmic Trading | Port for executable: 49997 | 2019-03-08 13:58:22
Listening socket (1048). Port 49997 | Closed. | 2019-03-08 13:58:22
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-03-08 13:58:22
Error creating process C:\SierraChart\Rim\DTCBridge.exe. Windows error code 2: The system cannot find the file specified. | 2019-03-08 13:58:22 *
Rithmic Trading | Error running DTC server program C:\SierraChart\Rim\DTCBridge.exe. | 2019-03-08 13:58:22 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-03-08 13:58:22
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-08 13:58:22
Rithmic Trading | Disconnected. | 2019-03-08 13:58:22
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-08 13:58:22
Rithmic Trading | Port for executable: 50020 | 2019-03-08 14:00:22
Listening socket (1400). Port 50020 | Closed. | 2019-03-08 14:00:22
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-03-08 14:00:22
Error creating process C:\SierraChart\Rim\DTCBridge.exe. Windows error code 2: The system cannot find the file specified. | 2019-03-08 14:00:22 *
Rithmic Trading | Error running DTC server program C:\SierraChart\Rim\DTCBridge.exe. | 2019-03-08 14:00:22 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-03-08 14:00:22
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-08 14:00:22
Rithmic Trading | Disconnected. | 2019-03-08 14:00:22
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-08 14:00:22
[2019-03-08 19:23:25]
In the case of Rithmic you need to install the optional files. Follow the instructions here for updating Sierra Chart and check the option to install Optional Files:
