Date/Time: Thu, 22 Oct 2026 22:00:05 +0000
Volume Per Bar chart problem
View Count: 986
| [2019-03-08 14:39:54] |
| User450509 - Posts: 1 |
Hello, I have recently had to update the session times for all my charts using volume bars as there was an issue with some charts having a session time from 23:00:00 to 22:00:00 and others 23:00:00 to 22:59:59 where the latter appeared to display much better information. In updating the session times in this matter, I notice that the graphs changed significantly and after some analysis, it appears they are ghosting volume numbers from other charts. Attached you will see a screen dump of what is supposed to be a 30k volume bar chart "http://www.sierrachart.com/image.php?Image=1552055801103.png " and a 120k volume bar chart "http://www.sierrachart.com/image.php?Image=1552055855877.png " displaying the NQ futures. I am using tick data feed and also split data records for both graphs. The only difference I can find between the charts is the volume setting but this does not seem to have an impact on the visible bars. Changing the volume number makes no discernible difference at all. I have also tried to re-set the time to what previously worked but with no result, everything remains exactly the same... The same problem is visible across instruments, CL, EU6, ES, and others. I have downloaded the latest version of sierra chart today, version 1882. Please respond soonest as my trading is completely halted because of this. Kind regards Date Time Of Last Edit: 2019-03-08 15:47:48
| [2019-03-08 15:49:03] |
We do not understand what you are trying to say here. What is the problem you are having? It is not clear to us.
