Date/Time: Thu, 29 Oct 2026 22:09:44 +0000
Hologram Thickness
View Count: 1196
| [2019-03-06 19:31:41] |
| User546533 - Posts: 5 |
Hi. Is there an update re ability to increase the thickness of the hologram VbP? Thank you |
| [2019-03-07 02:36:16] |
We are checking on this.
| [2019-03-13 17:40:42] |
Many thanks
| [2019-03-13 17:44:16] |
| John - SC Support - Posts: 48369 |
We just changed the ability for this to be controlled via the Width/Size setting of the Subgraphs in the VbP. The Volume Bar Outline and Fill Colors Width/Size controls the size for the Primary Session outline and the Evening Session Volume Bar and Fill Colors Width/Size controls the size for the Evening Session outline when the Evening Session is displayed separately. Note that this controls the size for the outline regardless of the Volume Bars Draw Method (i.e. it applies to all settings, not just Hologram). This will be available in the next Pre-Release (v1883). When available, you can perform a Fast Update to get to this version: Software Download: Fast Update For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-03-13 17:45:21
