Date/Time: Fri, 06 Nov 2026 18:27:51 +0000
Time Remaining in Chart Header not updating in real-time
View Count: 1308
| [2019-02-28 16:42:12] |
| tesseract353 - Posts: 66 |
This use to update in real-time, but stopped after I updated Sierra Chart. Is there a way to make it update in real-time again?
| [2019-02-28 18:23:58] |
It is not going to continuously update, only when there is a trade. You need to use the Countdown Timer study which supports real-time continuous updates: Countdown Timer Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-02-28 18:24:05
