Date/Time: Thu, 08 Oct 2026 20:49:17 +0000
Trail Stop
View Count: 892
| [2019-02-28 15:07:56] |
| User274676 - Posts: 38 |
Is there a way to set in parameters where let’s say I set take profit at 10 ticks but once price is up 5 ticks in my favour the stop loss moves to break even or +1 that way it saves me from manually moving stop. Thanks. |
| [2019-02-28 21:18:31] |
Yes this is supported with Attached Orders. Refer to: Attached Orders: Move to Breakeven for Stop Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
