Date/Time: Thu, 08 Oct 2026 20:49:17 +0000
drawing 70% and 90% Value Area on same profile
View Count: 883
| [2019-02-28 14:26:29] |
| User317484 - Posts: 15 |
Do you have any suggestion on how to draw a 70% and 90% Value area High/low on the same volume profile ? Thank you Steven Leon |
| [2019-02-28 21:13:38] |
You can add two instances of the Volume Value Area Lines study to the chart to do this. Each one configured for each percentage.
