Date/Time: Sun, 01 Nov 2026 10:27:48 +0000
Currency Value per Tick Study
View Count: 3010
| [2019-02-27 04:42:36] |
| User606491 - Posts: 164 |
Do any studies - custom or otherwise - show currency value per tick (i.e. ES: $12.5 // CL: $10)? I'd like to reference this directly, rather than utilize a spreadsheet. thank you. |
| [2019-02-27 18:42:15] |
In ACSIL you can use this variable: ACSIL Interface Members - Variables and Arrays: sc.CurrencyValuePerTick Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
