Date/Time: Thu, 08 Oct 2026 20:52:03 +0000
Candlestick Pattern Finder & Spreadsheet
View Count: 1171
| [2019-02-27 01:42:22] |
| David_M - Posts: 14 |
I can't adjust the Draw Style for Pattern 2 to 6. Each time it defaults back to Ignore. However, all Patterns are recognised on the chart. My issue is only SG1 is outputted to the spreadsheet. |
| [2019-02-28 21:23:44] |
Check this Spreadsheet Study input: Spreadsheet Study Inputs: Do Not Output Subgraphs Set To Ignore Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
