Date/Time: Wed, 18 Nov 2026 15:46:10 +0000
[Programming Help] - ACSIL: simple FOR loop , very long reload and recalculate time
View Count: 4439
[2019-02-26 16:16:50]
TedMar - Posts: 191
Hi, in my Example, try simple FOR loop. BUT this example "reload and recalculate" 26 secunds on 1 Day History and period 5 minutes chart. Whats wrong?
SCSFExport scsf_ExampleForCount(SCStudyInterfaceRef sc)
  SCSubgraphRef Graph1 = sc.Subgraph[0];
  if (sc.SetDefaults)
    sc.GraphName = "Example Count 4 Red Bars ";
    sc.StudyDescription = "Count RED Bars Serries in Manual loop";
    sc.AutoLoop = 0;
    sc.GraphRegion = 0;
    Graph1.Name = "Graph1";
    Graph1.DrawStyle = DRAWSTYLE_ARROW_DOWN;
    Graph1.LineWidth = 3;
    Graph1.PrimaryColor = RGB(255, 51, 255);
    return;
  for (int BarIndex = sc.UpdateStartIndex; BarIndex < sc.ArraySize; BarIndex++) //Manual Loop
    if (sc.Close[BarIndex] < sc.Open[BarIndex]) // find REDBAR
      int REDCount = 1;
      for (int i = REDCount; sc.Close[BarIndex - (REDCount)] < sc.Open[BarIndex - (REDCount)]; i++) //Count RedBars serie,this loop needs 26s for chart Reload 5m Chart on Intel i5 3,3Mhz
        REDCount++;
      if (REDCount >= 4)
        for (int i = 0; i < REDCount; i++)
          Graph1[BarIndex - (i)] = sc.High[BarIndex - (i)];
v1879
Date Time Of Last Edit: 2019-02-26 16:22:38
[2019-02-26 17:37:10]
TedMar - Posts: 191
@ackin Im not clear what u mean. Is posible u adjust my example? For me is not important green or red candels, but the code to get same effect but faster. @ackin u tryied my example, is similiery slow reload chart?
Date Time Of Last Edit: 2019-02-26 17:41:49
[2019-02-26 18:41:25]
TedMar - Posts: 191
@Ackin, thank u,in fact u example effect is same , but why takes FOR LOOP so long time on reload chart?
[2019-02-26 19:26:49]
TedMar - Posts: 191
@Ackin u tryed my Example and is result 10ms ?
Date Time Of Last Edit: 2019-02-26 19:28:09
[2019-02-26 20:21:29]
TedMar - Posts: 191
im confused, in v1879 need my example 26 >"SECUNDS"< for reload , and u Example Ackin needs 10 "Milisecunds" for 1 Day history / 5m bar period.
[2019-03-09 14:38:06]
TedMar - Posts: 191
@Ackin in your Example colorred GetPersistentInt counted RedBars. How is best way to remeber RedBarsseries and Last.Price for later calculation in an Array?
in my added lines in u example i use a subgraphArrey for store data, and i compare Last Array with current one
SCSFExport scsf_ExampleArrayCount(SCStudyInterfaceRef sc)
  SCSubgraphRef Graph2 = sc.Subgraph[1];
  if (sc.SetDefaults)
    sc.GraphName = "Example Array Cont ";
    sc.StudyDescription = "Count RED Bars ArraySeries";
    sc.AutoLoop = 1;
    sc.GraphRegion = 0;
    Graph2.Name = "Graph2";
    Graph2.DrawStyle = DRAWSTYLE_POINT_ON_LOW;
    Graph2.LineWidth = 3;
    Graph2.PrimaryColor = COLOR_BLUE;
    return;
  SCString message;
  SCFloatArray myArray = sc.Subgraph[2].Arrays[0]; // SubgraphArrey [2] for Calculate only
  int& colorred = sc.GetPersistentInt(1);
  if (sc.GetBarHasClosedStatus(sc.Index) == BHCS_BAR_HAS_CLOSED)
    if (sc.Close[sc.Index] < sc.Open[sc.Index])
    { //without DOJI
        colorred += 1;
    else {colorred = 0;  }
    if ((colorred) >= 4)
      for (int i = 0; i < (colorred); i++)
        Graph1[sc.Index - (i)] = sc.High[sc.Index - (i)];
      myArray[sc.Index] = sc.Close[sc.Index];
      if (myArray[sc.Index] < myArray[sc.Index - 1]) // Comapre Prices from last RedBarSeries
        Graph2[sc.Index] = myArray[sc.Index];
      message.Format("Array %i ", myArray.GetArraySize());
      sc.AddMessageToLog(message, 1);
is posible to resolve this comapre without subgraph array ? maybe with vector or other array type include sc.BaseData?
Please leve me example if u know.. THX
Date Time Of Last Edit: 2019-03-09 21:04:22
[2019-03-10 00:23:11]
TedMar - Posts: 191
its simple, i would like made Index of all (4Redbars series) , every serie + sc.Close Price from lastbar from serie,
After save them to array i.e , access to RedBar Series Index and lastBarprice , then compare RedBarSerie[sc.index -(x)][sc.Cloese] > RedBarSerie[sc.Index][sc.Close]
may question, how is best way to made index for this comparsion?
i see in my example
is wrong, in fact the myArray not Store Index of RedBarSeries, -1 bar is not RedBarSeries index , why?
by the way. i requested you directMessages authorization.
