Date/Time: Sat, 10 Oct 2026 12:55:23 +0000
Historical and Continuous Data problems for DJStoxx600 and OMXS30 Swedish futures indexes
View Count: 2263
| [2019-02-22 19:58:14] |
| ubmaitu - Posts: 4 |
Hello, I could not create a continuous futures chart for DJ600 and OMXS30 contracts. I can only create single futures charts for these two instruments. For the futures(e.g. Eurostoxx 50, ES) contracts listed in the "Find Symbol" window I can create continuous futures charts. Also DJStoxx 600 and OMXS30 cash index charts can only go back approximately 1 year. I use data for Interactive Brokers and I can see their historical data without a problem. The symbols that I use for the above mentioned contracts in SC are: DJ600-IND-DTB DJ600-201903-DTB OMXS30-IND-OMS OMXS30-201903-DTB Can you please help me receive the data the same way that I receive for the contracts that are listed in the "Find Symbol" window. Thanks Umit |
| [2019-02-25 19:42:39] |
Can you provide us a link to the exchange website page for each of these contracts containing the contract specifications. Also DJStoxx 600 and OMXS30 cash index charts can only go back approximately 1 year. This is a limitation on the Interactive Brokers side.
| [2019-02-27 18:34:07] |
We will set up the Symbol Settings and rollover rules for these.
| [2019-03-13 14:14:37] |
I couldn't find those symbols in the latest version 1882. Have you made the necessary adjustments?
| [2019-03-14 20:37:31] |
We are going to get to this as soon as possible. Today or tomorrow. We apologize for the delay.
| [2019-03-16 22:36:53] |
This is now done. Follow the instructions here to update the Symbol Settings: Global Symbol Settings: Update Global Symbol Settings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
