Date/Time: Thu, 26 Nov 2026 22:42:25 +0000
VolumeByPrice Source Code
View Count: 2170
[2019-02-20 09:50:13]
Jezz - Posts: 33
Hi
Is the code of the study VolumeByPrice available?
Thanks in advance
[2019-02-21 05:36:57]
No, refer to:
How to Build an Advanced Custom Study from Source Code: Source Code for Some Built in Studies Not Available
[2019-03-20 09:03:47]
Jezz - Posts: 33
There is a feature in Volume by Price that I'd like to incorporate in one of my studies:
When you set VbP to Visible bars, the profile is calculated despite the presence of realtime data. I mean the scroll action is detected independently from the next tick value. Whenever you change the scroll, the study is properly recalculated, even in disconnected mode.
In my study, I can achieve such recalculation (by monitoring sc.IndexOfFirstVisibleBar) but only when the next tick data is recieved, so it doesn't work in disconnected mode.
I've also tried sc.UpdateAlways = 1 without success.
How is it achieved in VbP?
Is there any way to detect horizontal scrolling in disconnected mode?
Any clue?
[2019-03-20 09:22:09]
In the case of ACSIL the only method to do this would be sc.UpdateAlways = 1. The study function will be continuously called at the chart update interval in that case and that is the only way to detect scrolling continuously.
[2019-03-24 10:06:10]
Jezz - Posts: 33
Thanks for your support
Other related question: Keyboard control of Volume by Price Study
One of the reasons for requesting the source code is to add some control via keyboard.
I guess it could be done from another study if there would be a pointer to the sc structure that can be accessed. Then some input parameters could be modified according to the desired keystrokes.
Is there such a pointer available in the study?
something like this :
sc.SetPersistentPointer(1, &sc);
If not, could it be included in next releases, please ?
Any other clue to achieve keyboard/ACSIL control of VolByPrice parameters?
Thanks in advance
[2019-03-25 19:02:36]
In regards to keyboard control, refer to:
Advanced Custom Study Interaction With Menus, Control Bar Buttons, Pointer Events
And you can also programmatically change study Inputs. Refer to:
ACSIL Interface Members - Functions: sc.SetChartStudyInputFloat()
Date Time Of Last Edit: 2019-03-25 19:02:57
