Date/Time: Thu, 19 Nov 2026 19:40:29 +0000
Cancel All Orders
View Count: 1716
| [2019-02-10 23:24:08] |
| User294224 - Posts: 43 |
is it possible to create a keyboard shortcut to cancel all orders on several different products at once from the keyboard? Alternately on the orders and positions window is it possible that all orders would be cancelled from clicking cancel all without the need for the confirmation box?
| [2019-02-11 01:35:45] |
You can disable the confirmation for that particular command: Global Trade Settings Windows: Display Confirmation for Order Cancellations from the 'Orders' Tab (Global Settings >> General Trade Settings >> Notifications) And we will support a keyboard shortcut for it in the next release. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2019-03-13 20:15:03] |
Hi, Was this keyboard shortcut ever added?
| [2019-03-14 00:45:51] |
Yes it is in Global Settings >> Customize Keyboard Shortcuts >>Trading Keyboard Shortcuts. You need to update to the current version: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
