Date/Time: Fri, 13 Nov 2026 20:19:55 +0000
troubles with connection
View Count: 908
[2019-02-05 14:41:19]
User30743 - Posts: 399
i am still having hard time to connect to rithmic feed..
Reading Internal Order ID file. | 2019-02-05 08:38:43
Reading Trade Orders file. | 2019-02-05 08:38:55
Reading Trade Positions and Account Balance file. | 2019-02-05 08:38:55
Listening on UDP port 22903. | 2019-02-05 08:38:55
Software version: 1781 64-bit | 2019-02-05 08:38:55
Usage end date: 2019-04-29 | 2019-02-05 08:38:55
Enabled for: Advanced Features. | 2019-02-05 08:38:55
Enabled for: Advanced Features 2. | 2019-02-05 08:38:55
Enabled for: Sierra Chart Historical Data Service. | 2019-02-05 08:38:55
Allow Support for Sierra Chart Data Feeds is enabled. | 2019-02-05 08:38:55
Current selected Data/Trading service: Rithmic Trading | 2019-02-05 08:38:55
Chart Update Interval: 100 | 2019-02-05 08:38:55
Time Zone: -06:00:00 (CST-06CDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2019-02-05 08:38:55
2019-02-05 15:38:55 Local computer time | 2019-02-05 08:38:55
2019-02-05 14:38:55 Local computer time in UTC | 2019-02-05 08:38:55
2019-02-05 08:38:55 Local computer time in SC Time Zone | 2019-02-05 08:38:55
Program path: C:\SierraChart\ | 2019-02-05 08:38:55
Data Files path: C:\SierraChart\Data\ | 2019-02-05 08:38:55
OS Version Number: 10.0 | 2019-02-05 08:38:55
Locale Setting: C | 2019-02-05 08:38:55
Checking for new symbol settings for service code rithmic.trading | 2019-02-05 08:38:55
HTTPS connection to www.sierrachart.com:443 (4) | Creating socket. Using TLS 1.2. | 2019-02-05 08:38:55
HTTPS connection to www.sierrachart.com:443 (4) | Connecting to IP: 46.4.97.203. | 2019-02-05 08:38:55
Symbol settings are up-to-date for rithmic.trading | 2019-02-05 08:38:55
Received 5 login tokens. | 2019-02-05 08:38:56
Rithmic Trading | Port for executable: 10986 | 2019-02-05 08:38:59
Listening socket (1288). Port 10986 | Closed. | 2019-02-05 08:38:59
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-02-05 08:38:59
HTTPS connection to www.sierrachart.com:443 (4) | Socket gracefully closed by remote side. | 2019-02-05 08:39:00
HTTPS connection to www.sierrachart.com:443 (4) | Initiating close of socket by core. | 2019-02-05 08:39:00
HTTPS connection to www.sierrachart.com:443 (4) | Received socket Close event. | 2019-02-05 08:39:00
HTTPS connection to www.sierrachart.com:443 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-02-05 08:39:00
HTTPS connection to www.sierrachart.com:443 (4) | Closed. | 2019-02-05 08:39:00
HTTPS connection to www.sierrachart.com:443 (2) | Socket gracefully closed by remote side. | 2019-02-05 08:39:01
HTTPS connection to www.sierrachart.com:443 (2) | Received socket Close event. | 2019-02-05 08:39:01
HTTPS connection to www.sierrachart.com:443 (2) | Initiating close of socket by core. | 2019-02-05 08:39:01
HTTPS connection to www.sierrachart.com:443 (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-02-05 08:39:01
HTTPS connection to www.sierrachart.com:443 (2) | Closed. | 2019-02-05 08:39:01
Rithmic Trading | Bridge process is running. | 2019-02-05 08:39:01
Rithmic Trading | Connecting to the server 127.0.0.1. Port 10986 | 2019-02-05 08:39:01
DTC Client socket (5) | Creating socket. | 2019-02-05 08:39:01
DTC Client socket (5) | Connecting to IP: 127.0.0.1. | 2019-02-05 08:39:01
Rithmic Trading | Connected to server. | 2019-02-05 08:39:01
Rithmic Trading | Starting socket receive thread. | 2019-02-05 08:39:01
Rithmic Trading | Sending encoding request to server: Binary VLS | 2019-02-05 08:39:01
Rithmic Trading | Setting DTC encoding to Binary VLS | 2019-02-05 08:39:01
Rithmic Trading | Sending logon request message. | 2019-02-05 08:39:01
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2019-02-05 08:39:01
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2019-02-05 08:39:01
Rithmic Trading | Message from server: Connecting to Rithmic Paper Trading server. | 2019-02-05 08:39:01
Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2019-02-05 08:39:03
Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2019-02-05 08:39:03
Rithmic Trading | Received logon response. | 2019-02-05 08:39:03
Rithmic Trading | Server Name: DTC Bridge. | 2019-02-05 08:39:03
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2019-02-05 08:39:03
Rithmic Trading | Logon error received from server | 2019-02-05 08:39:03
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-02-05 08:39:03
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-02-05 08:39:03
DTC Client socket (5) | Initiating close of socket by core. | 2019-02-05 08:39:03
Rithmic Trading | Disconnected. | 2019-02-05 08:39:03
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-02-05 08:39:03
DTC Client socket (5) | Shutdown started. Waiting for graceful close. | 2019-02-05 08:39:03
Rithmic Trading | Port for executable: 11000 | 2019-02-05 08:39:05
Listening socket (1292). Port 11000 | Closed. | 2019-02-05 08:39:05
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-02-05 08:39:05
Rithmic Trading | Bridge process is not running! | 2019-02-05 08:39:07
Rithmic Trading | Connecting to the server 127.0.0.1. Port 11000 | 2019-02-05 08:39:07
DTC Client socket (6) | Creating socket. | 2019-02-05 08:39:07
DTC Client socket (6) | Connecting to IP: 127.0.0.1. | 2019-02-05 08:39:07
DTC Client socket (6) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-02-05 08:39:08 *
DTC Client socket (6) | Initiating close of socket by core. | 2019-02-05 08:39:08
DTC Client socket (6) | Closed. | 2019-02-05 08:39:08
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-02-05 08:39:08
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-02-05 08:39:08
Rithmic Trading | Disconnected. | 2019-02-05 08:39:08
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-02-05 08:39:08
Rithmic Trading | Port for executable: 11005 | 2019-02-05 08:39:10
Listening socket (660). Port 11005 | Closed. | 2019-02-05 08:39:10
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-02-05 08:39:10
Rithmic Trading | Bridge process is not running! | 2019-02-05 08:39:12
Rithmic Trading | Connecting to the server 127.0.0.1. Port 11005 | 2019-02-05 08:39:12
DTC Client socket (7) | Creating socket. | 2019-02-05 08:39:12
DTC Client socket (7) | Connecting to IP: 127.0.0.1. | 2019-02-05 08:39:12
DTC Client socket (7) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-02-05 08:39:13 *
DTC Client socket (7) | Initiating close of socket by core. | 2019-02-05 08:39:13
DTC Client socket (7) | Closed. | 2019-02-05 08:39:13
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-02-05 08:39:13
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-02-05 08:39:13
Rithmic Trading | Disconnected. | 2019-02-05 08:39:13
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-02-05 08:39:13
[2019-02-05 15:58:13]
You are getting the "permission denied" error. Refer to the documentation here:
Rithmic Trading Platform Service: Permission Denied Resolution Procedure
Sierra Chart Support
Date Time Of Last Edit: 2019-02-05 16:23:31
