Date/Time: Thu, 19 Nov 2026 11:06:53 +0000
New Price Retracement Tool Behavior
View Count: 1037
[2019-02-03 22:28:31]
ThatsMrScalperToYou - Posts: 9
I just installed build 1865. I am not sure if this is a bug or just new behavior.
When using the price retracement tool (or any tool that has a start and end point), I used to be able to just click once on the start point then move the mouse to the end point and click again to set it.
Now, it is requiring me to click and hold on the start point then while clicking, drag the mouse to the end point and let go.
Is this a new "feature" or bug?
Thanks for all you do!
[2019-02-03 22:30:39]
Nevermind.
It looks as though there is a new default setting to "Support Drag for Drawing Creation/Modification" under tool settings.
Closing this post.
[2019-02-03 22:53:06]
This has always existed but by default it is off. It definitely should not be on.
