Date/Time: Fri, 06 Nov 2026 18:55:18 +0000
Incorrect list of available custom studies
View Count: 924
| [2019-01-31 21:47:20] |
| User138418 - Posts: 16 |
“Studies>Add Custom Study” shows a list of ‘available’ custom studies, but the list is incorrect. Many of the entries shown have been deleted from SierraChart > ACS_Source and many relatively new studies (and their DLLs) fail to show up. How to correct this?
| [2019-02-01 02:47:38] |
You need to delete the DLL files from the Sierra Chart "Data" folder and put any DLLs you want to use in that folder. This is the folder where DLL files are searched for.
