Date/Time: Fri, 06 Nov 2026 18:55:18 +0000
Ultra bond UBH19 recent bid/ask volume, Volume, Pull/stack only print @ 160.
View Count: 1186
| [2019-01-30 12:40:24] |
| IconBob - Posts: 61 |
Ultra bond UBH19 recent bid/ask volume, Total/Bid/Ask Volume Pulling and stacking only print at 160. If you need it I can send a chartbook with DOM. I have the latest pre-release 1866 installed. |
| [2019-01-30 19:58:03] |
We will look into this.
| [2019-01-31 08:20:24] |
We do not observe any problem with this at all using the Sierra Chart Exchange Data Feed. We see you are using Rithmic though. Make sure the Price Display Format is set to 1/32 in Chart >> Chart Settings and also for the symbol in Global Settings >> Symbol Settings. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-01-31 08:21:10
| [2019-02-01 00:02:24] |
I did a full reset on the symbols and that fixed the problem. Thxs
| [2019-02-01 02:57:31] |
Okay that is good.
