Date/Time: Fri, 30 Oct 2026 19:55:55 +0000
I have a footprint chart up but I don't have any ticks on it?
View Count: 972
[2019-01-28 21:44:10]
User144031 - Posts: 7
Hi'
I have a footprint chart working along with the DOM but I don't have any ticks on the footprint chart?
I looked through the forum notes and could not find anything.
Do I need to upgrade?
The chart is not blank it shows volume from left to right in green and red and large buy and sell orders on the chart and the VWAP is working the price is correct with the DOM going up and down.
Regards Will
[2019-01-28 22:11:32]
You need Sierra Chart service package 5 for this:
To change your Sierra Chart Service Package, select "Help >> Account Control Panel" on the Sierra Chart program menu. On the displayed webpage, click on the "Set Service Package for Renewal" link.
Or go to this page:
https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation
You will need to login if you are not currently logged in.
In the "Available Services >> Choose Usage Time Service Package" frame, select the Service Package that you want to set your account to. Press the "Set" button.
The remaining service usage time on your account will be adjusted based upon the cost of the package you are changing to. If the new package is a higher-priced package, then the usage time will be reduced due to the higher price.
There is no charge for changing your Sierra Chart service package. Only your Sierra Chart account usage time ending date is adjusted.
