Date/Time: Tue, 06 Oct 2026 10:44:15 +0000
Study Summary Window using one cell for two different conditions
View Count: 1407
[2019-01-27 12:29:08]
ILIM KIRGIZ - Posts: 187
Dear support,
After reading here Study Summary Window, I could not achieve what I need.
In basic, I have two similar studies to detect the trend direction. They are using color background based on alert condition. (I may use color bar based on alert condition study as well If you suggest doing so)
First one generates TRUE(1) when there is an uptrend and generates 0(false when there is not an uptrend) according to my formula.
The second one generates TRUE(1) when there is a downtrend and generates 0(false when there is not a downtrend) according to my formula.
I gave this studies the same name and same subgraph name as I want to see them in a single cell. But I can't view data of the second study in the same cell. Only true and false condition results of the first study is shown (long trend filter). What would be your suggestion to achieve this? It would be great If it can be handled with existing studies and capabilities without ACSIL development. If not, then I will contact my programmer per your walkthrough suggestion as well.
Thanks.
Date Time Of Last Edit: 2019-01-27 18:26:33
[2019-01-28 00:31:08]
You need to give the studies different names if you want to see them on the Study Summary. Or implement a custom study with ACSIL which can control the background color of the study summary cells for its subgraphs.
[2019-02-01 12:10:13]
If I give them different names I can't view them on the same cell. So implementing a custom study to control color would be the only option in this case.
Thanks.
[2019-02-01 17:13:21]
Yes.
