Date/Time: Mon, 02 Nov 2026 08:10:25 +0000
1 trade per bar
View Count: 1171
| [2019-01-26 13:53:52] |
| User875891 - Posts: 63 |
I was running an auto trade sim and received this error code "allow one bar per trade True" How is this changed to "False"? the documentation Ive found refers to "chart options" I dont appear to have T |
| [2019-01-28 19:44:16] |
We need to know what specific tool you were using for your Auto Trading - Study, Spreadsheet, or ACSIL program? If a study, which one?
| [2019-01-28 20:59:57] |
| User996274 - Posts: 96 |
Study trade based on alert condition Date Time Of Last Edit: 2019-01-28 21:48:50
| [2019-01-28 22:10:41] |
You need to update to the current version of Sierra Chart: Software Download: Fast Update The Trading System Based on Alert Condition study has an Input to control whether you want to allow one trade per bar or not. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
