Date/Time: Mon, 16 Nov 2026 21:43:58 +0000
[Programming Help] - problem with sc.GetStudyPersistentIntChart ?
View Count: 1168
[2019-01-22 09:35:14]
User30743 - Posts: 399
Hi, i am having troubles getting persisten Ints from different charts using sc.GetStudyPersistentIntFromChart
when i use sc.GetStudyPersistentFloatFromChartor sc.GetStudyPersistentDoubleFromChartit works fine, but sc.GetStudyPersistentIntFromChart doenst renturn any values, but zeroes
Date Time Of Last Edit: 2019-01-22 09:36:34
[2019-01-23 00:57:49]
It is very doubtful there is a problem with this. This is going to be a 15USD cost for us to run a test.
[2019-02-16 02:38:06]
User553714 - Posts: 186
User30743;
After a recent SC upgrade after an extended Christmas break I couldn't get my study to compile, this was due to recent sc function naming changes noted below.
I am not sure it's the same issue that you are having as you say you are getting zeroes? Have you resolved this and what was the issue?
sc.GetStudyPersistentIntFromChart = sc.GetPersistentIntFromChartStudy
sc.GetStudyPersistentDoubleFromChart = sc.GetPersistentDoubleFromChartStudy
These also changed names;
sc.SetACSToolButtonText = sc.SetCustomStudyControlBarButtonText
sc.SetACSToolToolTip = sc.SetCustomStudyControlBarButtonHoverText
sc.SetACSToolEnable = sc.SetCustomStudyControlBarButtonEnable
Regards
[2019-02-16 03:30:05]
No, this is not their issue.
