Date/Time: Wed, 28 Oct 2026 10:27:41 +0000
cannot install a fulling working copy of SierraCharts
View Count: 1032
| [2019-01-09 02:36:32] |
| User320981 - Posts: 8 |
My Sierra Charts does not work properly. Most of the studies of my current copy are missing. I try to download the current copy under "Help". Once downloaded, it will not fully install. It says there are missing files. Please help.
| [2019-01-09 03:28:15] |
This sounds like a problem caused by security software on your computer. We need to see the installer log after you try installing Sierra Chart. Here are instructions: Software Download: Providing Installer Log to Support We want you to install Sierra Chart using this link: https://www.sierrachart.com/downloads/SierraChartFileDownloader.exe And install Sierra Chart into the default folder. From what we see it is being installed onto the desktop. That is the wrong place. Do not use that location. It needs to be C:\SierraChart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-01-09 03:28:59
| [2019-01-09 23:12:57] |
I could not go into the SierraChartFileDownloader sub file. So I sent you the log from the text button labeled "Send Log to Support". I used "***" where it requested my name or email address.
Date Time Of Last Edit: 2019-01-10 03:42:40
| [2019-01-10 03:07:31] |
I have successfully installed from the link you gave me. You can close this thread. Thank you
