Date/Time: Sat, 24 Oct 2026 07:24:17 +0000
HKFE data, as US customer - direct from SC or must go through other provider then link?
View Count: 983
| [2019-01-06 19:12:53] |
| Chad - Posts: 247 |
Hi, I'm a US client, and looking to get access to real-time L2 quotes for HKFE instruments. Can I get a subscription directly through SierraChart, or must I purchase it through my broker for another platform (e.g. CQG) and link to SC from there? I've searched the Board for mentions of HKFE data, but all of the threads I found pertained to residents of Hong Kong. |
| [2019-01-06 19:29:33] |
You can definitely get the Hong Kong futures data through the Sierra Chart Exchange Data Feed. Refer to this page for pricing and set up instructions: Sierra Chart Exchange Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2019-01-23 05:53:39] |
| Chad - Posts: 247 |
One more question: is this data unfiltered? I ask because of the monthly cost through SCEDF relative to Interactive Brokers, but then again, IB's data is filtered 250ms snapshots.
| [2019-01-23 23:30:40] |
Yes the data is unfiltered.
