Date/Time: Fri, 26 Apr 2024 06:19:06 +0000
May I ask where can I subscribe to HKFE datafeed?
View Count: 595
[2019-01-05 20:51:19] |
This is not available to you since you are in Hong Kong. It is only provided exclusively to a trading educator in Hong Kong for their students use. We could give you the contact information for this trading educator.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-01-05 20:54:31
[2019-01-09 03:30:49] |
Yes this is the arrangement we have.
