Date/Time: Sun, 18 Oct 2026 09:49:22 +0000
[Programming Help] - Show price in Percentage on the Scale
View Count: 2574
| [2019-01-03 18:56:11] |
| Tariq - Posts: 16 |
I would like to replicated the way several instruments are shown on one chart (see attached image), with percentage comparison. I am able to create the chart of several instruments on one chart using Overlay study but not sure how to display their relationship in percentage. Any help would be appreciated. Basically I am looking for a study similar to "Percent Change Since Previous Close" but with flexibility to be able to choose from a desired date. Thanks. Date Time Of Last Edit: 2019-01-12 01:32:21
| [2019-02-18 18:56:12] |
| Tariq - Posts: 16 |
I figured this out with the help of folks at Convergent Trading. Created chart from the date in question. Added "Add Additional Symbol" study for more symbols. Added Percent change since Open study and set start time to First Bar in Chart and the value format to Percent. Its not a perfect looking but serves the purpose.
| [2019-02-20 22:28:44] |
I am able to create the chart of several instruments on one chart using Overlay study Instead you will want to use Add Additional Symbol:Add Additional Symbol Which we see you have mentioned in post #2. What you describe in post #2 is how this is done in Sierra Chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-02-20 23:24:30
