Date/Time: Wed, 30 Sep 2026 03:56:48 +0000
Trade activity log
View Count: 898
[2018-12-19 00:32:26]
User459170 - Posts: 262
When I save the trade activity log as a txt file, the entry exit times seem to change(it seems to add 7 more hours-06:32 becomes 13:32). What could be the reason?
Date Time Of Last Edit: 2018-12-19 05:33:15
[2018-12-19 18:10:50]
It depends on which method you use to save the file. If you select File >> Export, then the times are saved as UTC. If you select File >> Save Log As, then the times are saved as they are displayed in the Log.
This is explained in the fourth paragraph of this documentation:
Trade Activity Log: Importing and Exporting Data
