Date/Time: Tue, 06 Oct 2026 22:39:17 +0000
Incorrect Values in Range Bar Chart
View Count: 1177
| [2018-12-18 17:22:33] |
| User104352 - Posts: 10 |
Hello, when i select Range Bars for my Chart the TPO Value Area Lines Study does not show the same Values as the TPO Chart itself. If i switch to a time based chart the values are correct. How can i fix this? |
| [2018-12-18 18:08:25] |
We would expect this to be the case. Refer to: http://www.sierrachart.com/index.php?page=doc/StudiesReference/TimePriceOpportunityCharts.html#IncorrectValues There is no solution to this. Other than to use the TPO Value Area Lines study on a chart with fixed time bars. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
