Date/Time: Fri, 13 Nov 2026 16:39:32 +0000
подозрение в неверности котировок
View Count: 1065
| [2018-12-16 18:39:26] |
| User225658 - Posts: 5 |
Здравствуйте. Я вчера подключилась с помощью вашего сервиса напрямую к котировкам бирж NYSE, NASDAQ. Сегодня проанализировав котировки акции AADR (тикер акции) я увидела что в начале торгов огромный ГЭП (разрыв) вниз, которого на котировках других брокеров нет. Подробности на изображениях в приложении Hello. Yesterday I connected via your service directly to the NYSE and NASDAQ exchanges. Today, after analyzing the stock quotes AADR, I saw that at the beginning of trading a huge gap, which is not present with other data services. Details on the linked images https://www.sierrachart.com/Download.php?Folder=TicketingSystem&download=24388 https://www.sierrachart.com/Download.php?Folder=TicketingSystem&download=24389 |
| [2018-12-17 08:18:32] |
The data provided by the Sierra Chart Exchange Data Feed is definitely correct. Here is 1 minute bars from IQ Feed for the same symbol. You see the same gap: http://www.sierrachart.com/image.php?Image=1545034658473.png Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
