Date/Time: Thu, 01 Oct 2026 09:17:31 +0000
Data
View Count: 766
| [2018-12-12 15:24:02] |
| Jeffrey S - Posts: 42 |
I'm getting historic downloading, but not real time data. What should I check?
| [2018-12-12 19:04:01] |
What markets do you need data for or want to trade? For example, what particular futures, Forex or stock symbols. You can also give us the exchanges that the particular symbol or symbols trade on. If you require real-time futures data, then refer to: Is Historical and Real-time Data Included? Be sure to read the page linked above *completely* before you ask further questions about real-time futures data. And *think about that information* before you ask questions about real-time futures data. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
