Date/Time: Fri, 13 Nov 2026 16:49:33 +0000
[User Discussion] - Volume at Price for minute chart data
View Count: 1208
[2018-12-12 11:18:24]
pa_trader - Posts: 36
I'm using IQ Feed with "Intraday Data Storage Time Unit = 1 Minute", to run some longer term intraday analysis. If tick data is not available, how does SC plot the Volume at Price (using Draw Volume Profile tool). Does it assign volume for each underlying 1 minute bar at the closing price, or make assumptions about how it was distributed between O/H/L/C ? Thanks
[2018-12-12 20:12:56]
This section here explains how this is done and is also applicable to 1 minute data:
Volume By Price Study: How Volume by Price is Calculated for Historical Daily and Higher Timeframe Charts
Would you mind letting us know why you are using IQ Feed. We also see you are using the Sierra Chart Exchange Data Feed. If you want 1 minute data with the Sierra Chart Exchange Data Feed in addition to tick by tick data, you can use another instance of Sierra Chart for that. Refer to:
http://www.sierrachart.com/index.php?page=doc/ChangingPeriodOfBars.php#ImprovingPerformanceOfLoadingChartData
Date Time Of Last Edit: 2018-12-12 20:14:40
