Date/Time: Fri, 02 Oct 2026 12:28:38 +0000
Echo not working on 64 bit
View Count: 806
[2018-12-11 19:54:30]
User254425 - Posts: 3
I cannot get echo charts on a 64 bit computer. Works ok on 32 bit computer. I am informed that others have this problem
[2018-12-11 20:58:10]
You just need to use the 32-bit version of Sierra Chart:
Software Download: Difference Between 32 and 64-bit Versions
What you are referring to is custom studies that are not built for the 64-bit version of Sierra Chart.
