Date/Time: Fri, 13 Nov 2026 16:49:27 +0000
Long and Short Net Display
View Count: 913
| [2018-12-10 13:41:15] |
| User22511 - Posts: 1 |
Hi, I have 2 accounts with IB and want to trade both. One will be Short, the other Long. I know I can trade the two accounts simultaneously. But is there any way to display the net of the 2 accounts without having to reference them both manually. Hope that makes sense. Thank You! |
| [2018-12-10 20:13:49] |
No, that is not possible.
