Date/Time: Sat, 27 Apr 2024 03:10:21 +0000
my problem in the price
View Count: 438
[2018-12-04 18:47:43] |
You need to set the Scale Increment setting in the Scale Settings for the chart to what you require: http://www.sierrachart.com/index.php?page=doc/Scaling.html#ScaleIncrement Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-12-04 18:47:51
