Date/Time: Fri, 13 Nov 2026 16:55:49 +0000
User Questions
View Count: 2664
| [2018-11-27 01:08:19] |
Hello, My name is ***** I am actually looking for sales department with few questions before I am making my decision. I am trading stocks, options, ETFs, forex. 1. Do I have to buy any additional data services, what would me my total monthly fees? 2. Do you have any Black Friday )) promotions? Kind regards, Sierra Chart Support |
| [2018-11-27 18:24:21] |
1. We need to know if you require real-time data? The Sierra Chart provided data feeds only have futures options data. Not stock options data. But for stock options you can use Interactive Brokers which is a supported trading service. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2018-11-27 18:24:47] |
1. If you already have a data source from one of the vendors Sierra Chart can work with, then you do not need to purchase the Sierra Chart Exchange Data. In which case, your cost is just the cost for the Sierra Chart software, which is either $24 USD per month for Package 3 or $33 USD for Package 5. You will find the information on supported data providers here: Supported Data and Trading Services You will find the information on the Sierra Chart packages here: Description of Service Packages and Pricing: Packages If you are interested in the Sierra Chart Exchange Data, then that information can be found here: Sierra Chart Exchange Data Feed 2. No, we do not do any Black Friday promotions. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
